Activity › Forums › Apple Final Cut Pro Legacy › reversing field dominance
  • reversing field dominance
    Posted by Mykul235 on November 24, 2005 at 2:38 am
    I am having trouble switching the field dominance of clips that have their fields reversed. I have been trying the item properties – format option which allows you to set the field order but not reverse it. I have been getting this problem when using blackmagic upper field first clips in dv lower field sequences. There must be aa simple a way as it was in Premiere 6!! I am using the PAL format.
    Graeme Nattress replied 20 years, 10 months ago 4 Members · 6 Replies
  • Bryce Whiteside
    November 24, 2005 at 3:00 am
    Film Tools – some stuff to work more effective try The Shifter–it’s free. Then there is Nattress’s plug-ins at https://www.nattress.com.
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Mykul235
    November 24, 2005 at 4:10 am
    Thankyou. Works well if a littlt complicated. Why is this not a standard feature of FCP? Is it because it is mainly a PAL problem?
    Anyway, thanks for your help.
  • Jerry Witt
    November 24, 2005 at 8:08 am
    [mykul] “Why is this not a standard feature of FCP? Is it because it is mainly a PAL problem?”
    It is! Look under video filters > video > shift fields
  • Mykul235
    November 24, 2005 at 8:48 am
    is that only in version 5? I have 4.5!!
  • Graeme Nattress
    November 24, 2005 at 2:09 pm
    It is a standard feature, now built into FCP5.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Graeme Nattress
    Graeme
