Activity › Forums › Apple Final Cut Pro Legacy › Reverse telecine for DV NTSC transferred from 16mm: interlacing problem
  • Reverse telecine for DV NTSC transferred from 16mm: interlacing problem
    Posted by Chris Dukes on August 16, 2006 at 10:59 am
    I did a reverse telecine in Cinema Tools at F2 Only, Style 1, Field A. I wanted it to conform to 24fps. It worked well accept that every fourth frame is interlaced and I don’t want any of them to be. I tried it with several different settings and this seemed to be the best one. I thought about exporting the footage as Uncompressed 8-Bit and de-interlacing it before doing the reverse telecine but I’m not sure how good an idea that is. Thanks for any advice.
    Mech
    Chris Dukes replied 20 years, 1 month ago 1 Member · 1 Reply
