Activity › Forums › Apple Final Cut Pro Legacy › reverse telecine — compressor/Cinema tools both leave interlacing
  • reverse telecine — compressor/Cinema tools both leave interlacing
    Posted by Elise London on June 25, 2011 at 5:02 pm
    Hi — I am working with footage that looks like it has a 2:3 pulldown cadence.
    good frame, good frame, bad frame, bad frame, good frame.
    Tried Compressor’s reverse telecine, also Cinema Tools reverse telecine.
    Both produce a new file that still leaves one bad interlaced frame.
    What’s going on???Thx!
    Jeremy Garchow replied 15 years, 3 months ago 3 Members · 15 Replies
  • 15 Replies
  • Jeremy Garchow
    June 25, 2011 at 5:52 pm
    I’d stick with compressor. It’s easier.
    You are using the “reverse telecine” setting in compressor right?
    What format is the original footage? SD or HD?
  • Elise London
    June 25, 2011 at 5:57 pm
    Thanks. Yes I would prefer to stay with Compressor too. Yes I am using the ‘reverse telecine’ option within compressor’s deinterlace settings. The footage is SD.
  • Jeremy Garchow
    June 25, 2011 at 6:02 pm
    And this is footage direct from capture scratch?
    If so, make sure to single click on the clip thumbnail of compressor and in the a/v properties tab (I think that’s what it’s called, not by the computer) make sure that your source clip has a field Dom of lower.
    Hard to explain, easy to show. Hope it helps.
  • Elise London
    June 25, 2011 at 6:06 pm
    Yes the source footage has a native field dominance of ‘lower.’ Not sure why this would matter?
  • Jeremy Garchow
    June 25, 2011 at 6:21 pm
    Sometimes compressor guesses wrong and it doesn’t process correctly. You chose lower field in the a/v properties of compressor?
    Did you capture this footage? Is it an export from the timeline or is this footage right out of the capture scratch?
  • Elise London
    June 25, 2011 at 6:30 pm
    Yes it is footage straight from the capture scratch. Captured it from the DVX100 @ 24p.
  • Jeremy Garchow
    June 25, 2011 at 6:32 pm
    And is it one long capture? Meaning is the cadence broken at any point?
  • Elise London
    June 25, 2011 at 6:33 pm
    Correct the cadence is not broken
  • Jeremy Garchow
    June 25, 2011 at 6:44 pm
    I use this feature a lot and it works.
    Are you sure the footage is 24p and not 24pA?
  • Elise London
    June 25, 2011 at 6:50 pm
    Yes pretty sure. But either way, I have a file in front of me with a pretty obvious cadence that is unbroken. good good bad bad good
    Shouldn’t Compressor be able to handle this?
    What other options are there in Compressor — what could possibly lead to one interlaced frame remaining?
