Activity › Forums › Avid Media Composer › reverse speed and fitting to fill at same time?
  • reverse speed and fitting to fill at same time?
    Posted by Erin Greenwell on March 1, 2011 at 12:04 am
    Hello,
    I’m on an avid sympony nitris vers 1.83
    Have a bunch of clips that I want to reverse the motion within each clip
    then take all those clips and speed them up by a certain percentage
    the emotional effect is tape rewinding quickly past an entire story etc
    I have been googling this problem but want to tripple check I am not missing something:
    I can put the reverse motion filter on all clips in the sequence but then cannot put a timewarp effect on those filtered clips in the sequence
    tried collapsing the sequence and draggin on the timewarp- no dice
    tried alt dragging the time warp filter to the clips with the reverse motion filter- no as well
    exporting a movie of the sequence with all clips reversed and then applying fit to fill on that reference movie into a sequence does the trick but since the footage is offline quality, this will be a problem down the line for the upres
    is there a way to nest sequences and apply speed and reverse effects to the same clip in Avid?
    Advice appreciated
    E
    Kris Anderson replied 15 years, 7 months ago 2 Members · 1 Reply
  • Kris Anderson
    March 1, 2011 at 12:56 am
    Use the motion effect as per normal, select fit to fill and then just add a “-” (minus) symbol in front of the fit to fill value.
