Activity Forums Apple Final Cut Pro Reverse order of clips?
  • Reverse order of clips?
    Posted by Philip Nidler on December 8, 2019 at 9:38 am
    Hi!
    I’ve put down about 20 clips into the timeline, however for some dumb reason I started from the bottom up so now the last clip is first. Is there any way to reverse the order in the timeline with a button or a simple click instead of dragging each and every clip into chronological order?
    Thank you! 🙂
    Doug Suiter replied 6 years, 9 months ago 2 Members · 1 Reply
  • Doug Suiter
    December 10, 2019 at 5:32 am
    I was faced with this recently.
    Not one button, but try this:
    – Make sure “show used media ranges” is on
    – select the event(s) in the browser where your media is
    – click in the search bar, then click the icon next to it (it’s called Toggle Filter HUD)
    – Add the filter “Used”
    – now with what’s left, in column view arrange by content created / name / whatever else will set the in chronological order
    – select all
    – append edit (e)
    DOUG SUITER: FCPTalent
    Find Production and Post Production Talent, Free.
    web: http://www.fcptalent.com
    twitter: @FCPTalent
