Activity Forums Adobe After Effects reverse motion
  • reverse motion
    Posted by Shrapnel on February 10, 2006 at 12:24 am
    hey guys. i have a very simple problem that i just can’t remember how to do. i want to reverse motion on a layer, and i forgot how.
    can anyone remind me…thanks!
    Shrapnel replied 20 years, 7 months ago 3 Members · 6 Replies
  • Chris Smith
    February 10, 2006 at 12:38 am
    Just set the speed to -100%
    Chris Smith
    https://www.sugarfilmproduction.com
  • Shrapnel
    February 10, 2006 at 12:41 am
    where do i set the speed at?
    thank you so much for your time…
  • Arthur Vibert
    February 10, 2006 at 12:44 am
    option command r
    Arthur Vibert
  • Shrapnel
    February 10, 2006 at 12:53 am
    THANK YOU!
    will this work for reversing motion on a particular layer?
    basically, i’m using the organic lines preset and i need the lines to move out and then back in again…how is this achieved? thanks again!
  • Chris Smith
    February 10, 2006 at 2:38 am
    Organic Lines Preset in what? Particular? If so, you will have to pre-comp your layer. Then speed reverse the pre-comp. Because Particular is an effect that goes on top of a layer. If you speed reverse the layer you would just be reversing the solid, then putting Particular on top of that so you wouldn’t see a difference.
    Chris Smith
  • Shrapnel
    February 10, 2006 at 3:17 am
    Got it…thanks Chris! i speed reversed the actual particular layer at first, and it crashed. but the pre-comp works perfect!
    thanks again
