Activity Forums Apple Final Cut Pro Legacy Reverse merged clip
  • Reverse merged clip
    Posted by Simon Smith on August 21, 2008 at 9:13 pm
    Annoying problem …
    I’ve synced up audio and video clips of different lengths using the clapperboards. This usually results in a clip starting with audio, and then the video starting a couple of seconds later, as the sound recordist started recording earlier.
    I wanted to reverse one of these merged clips, but when I do so the audio and video don’t stay in sync.
    It’s too much to go and re-sync up reversed audio and video clips, I should be able to just drop them into a timeline and click speed>reverse!
    Any solutions? I can’t export them as new clips, reimport and then reverse those as it will mess with my conform, as we are working with offline files.
    Thanks. Simon.
    Simon Smith replied 18 years, 1 month ago 2 Members · 2 Replies
  • Andy Mees
    August 22, 2008 at 7:49 am
    try nesting.
    sync the clips in a sync sequence
    then use the sync sequence as a virtual source clip (a nest) in your master edit
    you apply the reverse to the nest
  • Simon Smith
    August 22, 2008 at 9:25 am
    The nest will mess up my conform though won’t it? I’m pretty sure our workflow doesn’t allow for nesting. Any other solutions?
