Activity › Forums › Adobe After Effects Expressions › reverse lines opacity animation
Posted by Aqeel Arruhaili on May 18, 2019 at 3:34 pmI have a text layer of three lines and I added an opacity animator to show lines disappear one after another from above to the bottom but what happened is the opposite .they disappear from the bottom to above.How can I reverse that …Thanks in advance.
Tomas Bumbulevičius replied 7 years, 4 months ago 2 Members · 5 Replies -
Tomas Bumbulevičius
May 18, 2019 at 5:06 pmHey Aqeel, in Text animator, under the Advanced section, change Mode from Add to Subtract.
Find out more:
After Effects Tutorials: motion design, expressions, scripting.
Boxer – Dynamic Text Boxes Template with a Live Preview -
Aqeel Arruhaili
May 18, 2019 at 7:21 pmThis shows text from the above line to the bottom but I want the text to disappear from top to bottom…
Tomas Bumbulevičius
May 18, 2019 at 8:46 pmJust set it to subtract and play around with start/end values to achieve result you are looking to have.
Its either:
Start: 100
End: 0And you animate End 0..100, or vice versa.
Other way, is to keep Start 0, End 100, and animate offset from -100..100. That way you would get fadeIn & fadeOut with a single controller.
Find out more:
Tomas Bumbulevičius
May 20, 2019 at 2:58 pmAqeel – did it helped and you managed to sort it out or I just created confusion? (:
In case if option NR 2 – just add your test project with what animation you have applied already and it will be the easiest way to help you get through.
Find out more:
