Activity Forums Adobe Premiere Pro reverse footage
  • Tim Kurkoski
    July 27, 2006 at 5:15 pm
    There are several video effects that will do this for you. It’s been a long time since I worked in 6.5, but there may be some in the Distort or Transform folder. There’s actually an effect called Transform in there somewhere, and if you use a -100% value on the horizontal scaling, it will mirror-flip the image.
  • Raine Parrish
    July 27, 2006 at 6:45 pm
    Thank you so much, I’ll give it a try!
