Activity Forums Adobe Premiere Pro Reverse clips to AE problem
  • Reverse clips to AE problem
    Posted by Tomadonna on August 10, 2007 at 12:03 pm
    I’m trying to import a PPro project into AE, and have noticed that AE ignores and changes the In/Out points for each clip that was reversed in PPro(regular speed-changed clips work fine)…
    Has anyone else experienced this issue or maybe know of a possible workaround?
    Alex Udell replied 19 years, 1 month ago 2 Members · 1 Reply
  • Alex Udell
    August 10, 2007 at 1:15 pm
    If you’ve finalized the edit decision with regards to those reversed clips, you best bet is to perhaps:
    In premiere pro:
    1) One by one, copy the reversed clips to new timeline and export them as new media files. Make sure you account for transition handles in the export.
    2) Import the Exported clips and use them as the sources on your timeline. (replacing the original clips with the reversed effect)
    This new project should come accross to after effects just fine.
    Alex
