Activity Forums Adobe Premiere Pro Reverse clip freezes playback.
  • Reverse clip freezes playback.
    Posted by Trevor Horigan on January 29, 2015 at 1:16 am
    Hi all,
    I’m using the latest version of Premiere Pro CC. I’m trying to reverse the speed of a clip on my timeline. I hit (command) R and select the checkbox for “Reverse Speed”. I try to playback the sequence and it is frozen. If I try and reverse the clip using “Time Remapping” the keyframe will only move about 1/10th of the way from the beginning of the clip to the end. FYI the filetype for the clip is an .MXF straight from a C300. Can someone explain why this is happening?
    Trevor Horigan replied 11 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
