Activity › Forums › Apple Final Cut Pro › reveal in finder option greyed out for compound clips, render files disappear, library is from backup
  • reveal in finder option greyed out for compound clips, render files disappear, library is from backup
    Posted by Chris Walker on November 24, 2015 at 6:33 pm
    I had a corrupted event or project so I needed to “restore from backup” to continue editing. Now fcpx opens a library with one of those long backup names. Everything seems to be there and working correctly as I continue to edit, although there is the yellow exclamation point sign on my event. But I notice two quirky things going on. One is that if I select a compound clip in the browser, the “reveal in finder” option is greyed out. The other is that sometimes when I render a clip in the timeline, the render later disappears and I have to re-render, even though I did nothing to the clip after the original render. I assume this has something to do with this being a backup and/or the yellow exclamation point warning. How can I get back to working from a regular library, or otherwise solve these problems? How can I find out what the warning means?
    Jeff Kirkland replied 10 years, 10 months ago 3 Members · 3 Replies
  • Bret Williams
    November 24, 2015 at 6:42 pm
    Not sure about the render issues, but compound clips don’t exist on the finder so it should be greyed out.
  • Chris Walker
    November 24, 2015 at 7:09 pm
    Thanks for the info re compound clips, I hadn’t really tried to find them before. Do you know how I can research what the exclamation point means? I’d hate to lose all the work I’ve done so far. When you are working from a backup, I assume that further backups are still being made so if the event gets corrupted again you can still “restore from backup”?
  • Jeff Kirkland
    November 24, 2015 at 7:53 pm
    Here’s a link to a list of alert icons in FCPX if that helps.
    https://help.apple.com/finalcutpro/mac/10.2/#/verd1f977a7
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
