Activity Forums Adobe After Effects Return actual Rotation from a layer Auto-Oriented along path
  • Return actual Rotation from a layer Auto-Oriented along path
    Posted by Mikael Holmström on June 30, 2016 at 7:17 pm
    Hi all,
    I would like to inherit the actual Rotation value from a layer that is Auto-Oriented along a path onto the rotation property of another layer. I would like this to happen with a small delay. I have tried:
    thisComp(layer(”Auto-Oriented_layer”).transform.rotation.valueAtTime(time-i))
    but it doesn’t consider the rotation that is caused by the Auto-Orientation mode.
    Mikael
    Mikael Holmström replied 10 years, 2 months ago 3 Members · 4 Replies
  • Kalleheikki Kannisto
    June 30, 2016 at 8:27 pm
    This Dan Ebberts expression gives you the rotation value, just need to modify it with valueAtTime()
    L = thisComp.layer("Auto-Oriented_layer");
    v = L.toWorldVec([1,0]);
    radiansToDegrees(Math.atan2(v[1],v[0]))
  • Mikael Holmström
    June 30, 2016 at 9:06 pm
    Thank you. Do you have an idea where to put the ValueAtTime() to make it work?
  • Walter Soyka
    June 30, 2016 at 9:52 pm
    toWorldVec takes time as an optional second parameter.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Mikael Holmström
    June 30, 2016 at 9:55 pm
    It works like magic, thanks!
