Activity Forums Storage & Archiving retreive info from LTO
  • retreive info from LTO
    Posted by Hernan Caratozzolo on June 8, 2011 at 1:34 pm
    Hi
    I would like to know if I need the same software that someone use to archieve info inside the LTO to retieve the data.
    More details: I am looking at Cache-A, Tolis + HP; Should the user buy the same software that I use to archieve to retrieve the info?
    Regards
    Hernán.
    Hernan Caratozzolo replied 15 years, 3 months ago 2 Members · 2 Replies
  • Andrew Richards
    June 9, 2011 at 4:59 pm
    Most likely you will need the same software, unless the LTOs were written with standard TAR (Cache-A does this by default) or the new LTFS (which, as far as I know, has been added as an option by both Tolis and Cache-A for LTO-5 setups). Almost anything else will require the same software that wrote the tape to read the tape. Check with individual vendors to know for sure.
    Best,
    Andy Richards
    VP of Product Development
    Keeper Technology
  • Hernan Caratozzolo
    June 13, 2011 at 1:08 pm
    Thank You very much for your time, answering this basic stuff.
    Regards,
    Hernán.
