Activity Forums Creative Community Conversations Retina Disply Ramifications
  • Retina Disply Ramifications
    Posted by Gary Slickman on June 14, 2012 at 1:48 pm
    With the transition into the Retina Display Era, I was contemplating the cascading implications, which I hope the forum will shed some light on. My strength lies in imaging, editing and story telling and not so much in the deep technical realm that lives “inside the box” so guidance in this area would be appreciated.
    Certain image sizes and resolutions have become standard over the years such as creating screen images at 72 or 96ppi and small manageable videos like 640 x 480 for SD and 640 x 360 for HD, all of which can be more easily transmitted and shared with even email.
    Will there now be a need to increase the pixel density on stills for example in order to obtain a reasonable sized, non pixilated image on these new 220ppi + or – displays?
    How will this impact the perceived image size and quality of the smaller draft or proof sized videos?
    As we move more and more away from the physical to the meta-physical with the cloud phenomenon
    won’t file sizes and possibly data rates have to increase in order to keep up with the higher resolutions,
    which impacts and adds stress on the pipelines to the sky?
    Rick Lang replied 14 years, 3 months ago 8 Members · 10 Replies
  • 10 Replies
  • Walter Soyka
    June 14, 2012 at 2:07 pm
    With video, I don’t generally think in PPI or DPI — those numbers are only meaningful if you know both the pixel count and the display size, and display size isn’t a factor in most video production (though it certainly does impact large-format and theatrical work).
    It’s usually better to think it terms of pixels only. If you want the sharpest possible imagery on a retina display, you’ll have to get as close as 1:1 in pixels (from source to display) as possible — just like any other video device.
    Walter Soyka
  • Rafael Amador
    June 14, 2012 at 3:44 pm
    [Walter Soyka] ” If you want the sharpest possible imagery on a retina display, you’ll have to get as close as 1:1 in pixels (from source to display) as possible — just like any other video device.”
    Which means that any picture displayed at full quality (1:1) will look smaller on a Retina display than on a non-Retina display of the same size. Isn’t it?
    Then I guess that when editing something smaller than 1280×720 will be necessary to set the canvass bigger than 100%.
    rafael
    http://www.nagavideo.com
  • Gary Huff
    June 14, 2012 at 4:17 pm
    I’m really interested on these ramifications. I don’t think we’ll get the whole story until someone uses it to edit on.
    Especially interested in how FCP Classic/Premiere work on that screen.
  • Rick Lang
    June 14, 2012 at 4:30 pm
    Look at the posts related to this in the earlier thread:Very specific question re: Retuna Macbook Pro
    TO RESPOND TO THIS POST, CLICK ON THE FOLLOWING LINK:
    https://forums.creativecow.net/readpost/335/37318
    Or, click on the following link to view the entire thread.
    https://forums.creativecow.net/thread/335/37157#37318
    Rick Lang
    iMac 27” 2.8GHz i7 16GB
  • Kevin Patrick
    June 14, 2012 at 6:05 pm
    For someone who doesn’t understand the ramifications, they may not be happy with the result.
    I didn’t use a calculator, but isn’t the retina display twice the number of pixels of the non-retina version?
    So non-HD video (youtubers) will wind up with videos playing at half the size. “Look at my cool new Retina display, where some things are now half as big? WTH?” (maybe I’m not thinking this through)
    Even 1080 won’t fill a 15 inch retina display. Which is probably a good thing for editing HD. So an editor might find a retina display useful. But a YouTuber might not.
    I do wonder how much extra burden this puts on the system. You are pushing around twice as many pixels.
  • Jim Wiseman
    June 15, 2012 at 5:29 am
    AnandTech has a review on the Retina running Windows 7 and 8 that shows the display in 8 scaled 100, 125, and 150 percent that can be displayed at original size as well as fit to browser window. Looks very sharp at all scalings. Here is the link to the display grabs, you can back track for the review. https://www.anandtech.com/Gallery/Album/2080#1
    Jim Wiseman
    Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.5 and 6.0, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM GTX-285 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe
  • Rick Lang
    June 15, 2012 at 8:43 pm
    Looking at the screen captures in the AnandTech galleries for the Macbook Pro Retina, it does look like it’s capturing pixel-doubled data. I took the screen capture for the 1280×800 option and at actual size displayed on my 27” iMac, the image filled my screen for the width and exceeded by height (iMac at 2560×1440). That is still understandable in the sense that the Retina screen has 2880×1800 physical pixels. What surprised me was when I looked at the screen capture for the 1920×1080 option on the Retina display. On my iMac I could only see a portion of the screen because it appeared the screen capture was 3840×2160 pixels; that’s more than the physical pixels on the Retina display! This conclusion was also supported by a post in Apple’s Discussion forum on the Macbook Pro, which said all screen captures are pixel doubled the virtual screen size defined in System Preferences/Display panel. So that 1920×1080 is pixel-doubled internally in the graphic chips to 3840×2160 and then scaled back to fit the 2880×1800 physical limitation of the Retina display. Now it’s all making sense what Apple’s doing.
    Still individual applications like Aperture and Final Cut Pro X 10.0.5 are not being pixel-doubled when they are displaying the photo or video imagery. That stuff is true pixel-for-pixel if you select to display the graphic as ‘actual size’ within those applications. I think I can rest now… been reading this stuff for many hours. And in spite of all that reading on one has mentioned how Quicktime behaves… hope it’s like Aperture and FCPX but eerie no one cares. I did read that Apple’s Preview application is also ‘Retina ready’ and it’s graphic imagery is also pixel-for-pixel. I’ll post later when I learn about Quicktime.
    Rick Lang
  • Rick Lang
    June 19, 2012 at 11:29 pm
    Sorry I forgot to post after Dave Jenkins confirmed that QuickTime does display pixel-for-pixel video. So if you open a HD video and display it at actual size, it does use 1920×1080 pixels on the screen out of the 2880×1800 available pixels. A screen grab of the contents will result in a capture of 1920×1080 pixels. Hopefully you already saw this posted in a couple if other recent threads.
    Rick Lang
  • Adam Rainer
    June 22, 2012 at 1:06 pm
    Will the MBPr hog the Nvidia GPU resources compared to the non-retina MBP ?
  • Rick Lang
    June 22, 2012 at 1:46 pm
    [Adam Rainer] “Will the MBPr hog the Nvidia GPU resources compared to the non-retina MBP ?
    Certainly it can take more effort to drive the retina display than the non-retina display but in the following benchmark results, the Macbook Pro with Retina display does not seem to be suffering when compared to the traditionally designed Macbook Pro at comparable CPU/GPU speeds. For the processing of large files, the SSD is going to perform better than HDD-based system. AnandTech has done some benchmarks of various SSDs by the way and is favourably impressed with the choices Apple’s made for their machine:
    https://www.anandtech.com/show/6005/apples-new-ssd-its-fast
    If the Retina machine’s ports (no Firewire and Ethernet support without using an adapter) suit your purposes and the cost is not prohibitive, I’d certainly go with the Retina display model since overall it does seem to be the better performer. Although the GPU speeds are the same, I’d recommend the 1 GB GDDR5 GPU memory option on either machine. Take a look at these comparisons:
    https://www.macworld.com/article/1167330/macbook_pro_15_inch_and_13_inch_non_retina_models_occupy_the_consumer_space.html
    Rick Lang
