Activity › Forums › Apple Final Cut Pro › Retiming bars
  • Retiming bars
    Posted by James Ewart on June 9, 2015 at 5:26 pm
    When I have finished with my retiming in a timeline, the retime bars at the top of each clip remain even when rendered. BUT when I close and then reopen the timeline, the retime indicator bars disappear.
    If I select a clip in the timeline and then retime again and slow down by, say 50%, the bar reappears and then if I ‘undo’ the indicator bar comes back showing how much the original clip in the timeline had been adjusted by when I was working on it previously.
    Where do I see how much the clips in the timeline have been adjusted by in terms of timing when i reopen a timeline please?
    It does not appear to be a preference issue as I have trashed already.
    James Ewart replied 11 years, 3 months ago 3 Members · 3 Replies
  • Doug Metz
    June 9, 2015 at 6:35 pm
    With the retimed clip in the timeline selected, hit command-R. This toggles the visibility of the retime bar at the top of the clip.
    Doug Metz
    Anode
  • Andy Neil
    June 9, 2015 at 7:22 pm
    If you want to see all your retimed clips, just select your whole timeline and hit CMD+R as Doug said. This will toggle visibility of the retime bar. You’ll be able to tell at a glance what’s slow (orange), frozen (red), fast (blue) or normal speed (green).
    Andy
    https://plus.google.com/u/0/107277729326633563425/videos
  • James Ewart
    June 10, 2015 at 4:17 am
    Thanks all.
    Senior moment!
