Activity › Forums › Apple Final Cut Pro › Retime to specific time length?
  • Retime to specific time length?
    Posted by Ian Page-echols on June 11, 2012 at 8:05 am
    I shoot a ton of time lapse videos using my GoPro cam. I take these huge folders of images, open QuickTime Pro 7 and “open image sequence” and save out a reference file. Is there some way to retime these huge clips to some specific length? Say, 10 seconds? The only thing I’ve figured so far is to retime them at a macro level, zoom in, retime, zoom in, retime, until I can get to the micro level where I can set the playhead, shift right arrow over how ever many seconds I want to try.
    One possibility I thought of was to make an AppleScript that copies 300 photos to another folder, evenly spaced through the sometimes thousands of photos from each time lapse. Retiming after that would involve running the script again to get a different number of frames from the original folder.
    Anyone else do ridiculous time lapses and have some interesting way of dealing with them? I don’t mind retiming when I want to change the pacing of something, but I’d love for this initial process to be somewhat easier.
    Danke, Ian
    T. Payton replied 14 years, 3 months ago 2 Members · 1 Reply
  • T. Payton
    June 12, 2012 at 4:43 am
    Humm. I’m using the same workflow as you but don’t having trouble. You might try to work with the time-lapse natively in FCP X.
    Import your stills and make them into a multiangle clip. If you check out this video there is a brief demo of at about 50 seconds:
    https://www.apple.com/finalcutpro/whats-new/#multicam-learn
    Once that clip is in the timeline retime as necessary watching the selection details at the bottom of the timeline. If you have to do an extreme retime of over 2000%, it might be best to adjust the duration of individual shots in the multi angle editor to get the complete duration in the ballpark. Select all of the shots and then control-d to set the duration of each frame.
    I hope this helps!
    T. Payton
    OneCreative, Albuquerque
