Activity › Forums › DaVinci Resolve › Restoring VHS video exported from Topaz
  • Restoring VHS video exported from Topaz
    Posted by jerry rio on December 18, 2024 at 5:05 pm
    I had Topaz Labs support do a test on a video that was restored in Topaz.
    Please let me know if you think I’ve come pretty close to what Topaz Labs did.
    This was a 480i video that was originally an interlaced 8 bit video that was shot on S VHS and digitized with a Canopus AV 110. 29.7 FPS
    What can I do in Resolve to improve the Topaz render?
    Here is the original AVI file
    https://drive.google.com/file/d/1zF2Ex7wUuwJ5rvuOBUBtfaDeOm4L3Y9_/view
    Here is the video after Topaz deinterlace and upscale
    https://drive.google.com/file/d/13O0Rx9IMHT-T8fkPXqUrjdt88f8CVdfJ/view
    This is my Render on Youtube as I will be using it to create “shorts”
    https://youtube.com/shorts/4w_3Fph1wTA?si=FhAFJdZDz53d_sqb
    Here is the method that Topaz labs used
    “”I ran some tests and found that the settings in the screenshots below had the best results. I used Dione TV to handle the deinterlacing and then added a second pass enhancement (to enable go to File > Preferences > Advanced > Features > Show second enhancement feature) with Artemis with an input condition of aliasing or moire.
    It’s not perfect, but since the input video quality is rather low quality to begin with, the AI models struggle to have enough pixel data information. These settings kept more of a “true” look as some of the models like Iris, Rhea, and Proteus can introduce some odd looks in the faces when it is trying to interpret them.”
    It looks pretty good and it doesn’t have any distorted faced in the background. The only procedure that was able to upscale to FHD without that happening was using this method.
    Are there any suggestions you would have for enhancing it and color correcting in Resolve?
    I know the lighting in the video is weird so sometimes the subject looks too dark. I can’t seem to lighten it or raise the lift without throwing the whole thing off balance. Also I’d like to get some of the redness out of the skin tones.
    Any help would be greatly appreciated.
    THANKS
    12th Gen Intel(R) Core(TM) i7-12700 2.10 GHz
    64.0 GB (63.7 GB usable) RAM
    Windows 11 Home
    RTX 3060 TI
    RESOLVE VERSION 19.0.1 build 6
    jerry rio replied 1 year, 9 months ago 1 Member · 0 Replies
  • 0 Replies
