Activity Forums Apple Final Cut Pro Restoring the window layout pane hang
  • Restoring the window layout pane hang
    Posted by Frank Valtellina on April 5, 2012 at 8:14 am
    I have a problem during launch with FCPX getting stuck at the “Restoring the window layout” pane.
    I had customized my Keyboard layout and If I chose that customized layout and quit FCPX, it hangs on relaunch.
    If I use the Default Keyboard Command layout and quit FCPX, it relaunches fine.
    The only way to relaunch the program is delete preferences “com.apple.FinalCut.plist” and “com.apple.FinalCut.plist.lockfile”
    The issue is come out suddenly.. it has always worked fine till now.
    Some advice?
    Don Montalvo replied 13 years, 6 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    April 6, 2012 at 12:52 am
  • Frank Valtellina
    April 7, 2012 at 8:58 am
    Thank you Jeremy but it doesn’t solve the issue.
    Any time you use the customize keyboard it stuck on launch.
    For solve the problem you have to select default keyboard before close Final Cut X
  • Don Montalvo
    November 6, 2012 at 1:45 am
    Well, 10.0.6 does not resolve this issue. 🙁
    Don Montalvo, TX
