Activity Forums VEGAS Pro Restore Vegas 9 Screen Defaults
  • Restore Vegas 9 Screen Defaults
    Posted by John Gregoriades on March 25, 2010 at 8:27 am
    Hi again,
    I suddenly have troubles. The default “screen” was: the Timeline across the entire bottom third of the screen, Video Preview and Project Media on Right and left, and tabs for other functions, e.g. Generated Media (again, jostling each other across the top 2/3rds.) Suddenly each of the above functions seems to want to take up the entire top portion, above the timeline, once its tab is clicked. They can be moved but then snap into place. Worse, if one clicks anywhere on the Timeline, it immediately jumps and takes up the entire screen. For example, a setup with the timeline below, and the Video Preview above it, if one clicks to move the cursor, or even clicks the Play, the Timeline enlarges and completely blocks the Video Preview, and must be manually dragged down to a smaller size to reveal the Video Preview (which is playing all along.)
    I cannot think that I did anything to cause this, except that once I did drag down the Video Preview window, to enlarge the picture as much as possible. This may have triggered the problem. Is there a way to get back to “defaults?” (Using the preferences-default did not work. Nor rebooting, etc.) Thank you
    John
    John Gregoriades replied 16 years, 5 months ago 2 Members · 4 Replies
  • Theo Van laar
    March 25, 2010 at 9:49 am
    Just try Ctrl + Alt + D
    Theo
  • John Gregoriades
    March 25, 2010 at 10:29 am
    Thank you, Theo. Unfortunately Ctrl+Alt+D had no effect. There must be another way to “lock down” the Timeline so it does not jump and cover the whole screen, when any part of it is clicked. (Then it can be dragged down to reveal what was above, but that’s not helpful.) Hopefully there is another way….? Also to show the other windows normally, on the top part.
    John23GR
  • Theo Van laar
    March 25, 2010 at 1:05 pm
    What about VIEW-WINDOW LAYOUTS-DEFAULT
    Theo
  • John Gregoriades
    March 25, 2010 at 9:25 pm
    Thank you again, Theo.
    I eventually found the control under: Options/Preferences/Display/Default All/Apply.
    ….Whew!…
    John23GR
