Activity Forums Blackmagic Design resolving that couple of frames audio delay in CS 6
  • resolving that couple of frames audio delay in CS 6
    Posted by Chris Borjis on June 20, 2012 at 6:18 pm
    The Issue:
    Load a project in Premiere CS 6.
    play the timeline.
    External monitoring is a few frames off.
    stop playback.
    re-start playback.
    External monitoring is spot on accurate.
    Is there anything that can be done to resolve this?
    It’s a bit annoying having to stop and restart the timeline
    for clients. Sometimes I just play it only the first time,
    then they comment the synch is off and I have to explain
    this whole thing to them.
    my multibridge and decklink systems both do it.
    it was an issue in cs 5.5 as well.
    Chris Borjis replied 14 years, 1 month ago 2 Members · 3 Replies
  • Carl Schuurbiers
    June 22, 2012 at 10:36 pm
    Hi Chris,
    What hardware/software are you talking about?
    I’m on a Mac Pro with Quadro4000 and Decklink SDI. In my situation everything just happens about 5-6 frames later on the external monitor. Always. It’s funny, I can quickly scrub back and forth on the timeline and see the same thing happening first on the program monitor and then again a bit later on the external monitor. Well, not that funny actually, it screws up my audio sync completely for the external monitor. Program monitor and external monitor should be sync!
    Also had the same problem in 5.5, but there it was “only” 1-2 frames.
    BTW: I filed a bug report with Adobe, but where does one report bugs to BMD?
    Are people with higher-end cards also experiencing these problems?
    Cheers,
    Carl.
  • Carl Schuurbiers
    June 23, 2012 at 6:23 pm
    BTW: I also put in a feature request at Adobe for a compensation setting in the preferences of Premiere, so one can delay the program monitor to match the delay in the external playback chain. So at least the program monitor and external monitor are sync when playing back.
    That said I do think the current delay is a bit much, probably there are thinks to optimize in the playback engine and/or BMD driver?
    Carl.
  • Chris Borjis
    July 24, 2012 at 5:12 pm
    I think its a mercury transmit/adobe issue.
    the aja cards seem to have it as well for some folks.
