Activity › Forums › DaVinci Resolve › Resolve not showing clips in monitorin either EDIT, COLOUR or DELIVERY mode
Posted by Mathew H green on May 15, 2015 at 11:53 pmHey
I can’t get it to show what’s on the timeline on the monitor in Resolve..
When I export no video comes out either!!Any ideas?
Thanks in advance
MatFrank Schumacher replied 11 years, 3 months ago 4 Members · 6 Replies -
Marc Wielage
May 16, 2015 at 4:20 amWhich operating system? Which version of Resolve? How are the monitors connected? What specific hardware are you using? What standard is the timeline in, and what standard are you monitoring in? Are you using an external color-managed output?
Has this ever worked before, or did it just now suddenly break?
Mathew H green
May 16, 2015 at 1:34 pmHi
Thanks for the response..win7
11.3
Sorry what I meant was the Monitors in the software. the little windows…
On a different timeline in the same project the video clips come up but not in this timeline..
Any ideas?
Cheers
Mat -
Glenn Sakatch
May 16, 2015 at 3:43 pmis your video track muted?
is there a layer above your video track you want to see?
Can you match frame a clip on your video track and get it to show up on the source side?Glenn
Mathew H green
May 17, 2015 at 6:22 pmnot muted.
I simply did an import of a XML file and then started colour correcting..
Has never come up in the monitor when playing it..
as mentioned before all other timelines are ok..
including new ones..im not sure how to add a track node??
