Activity Forums DaVinci Resolve Resolve Lite 10 – FX button not responding
  • Resolve Lite 10 – FX button not responding
    Posted by Kenneth Merrill on December 20, 2013 at 7:06 am
    Hello all!
    I am brand new to DaVinci (or any coloring software for that matter), and still learning the ropes. So, if this is a non-issue, I apologize, and I greatly appreciate any help.
    I’m trying to use an OFX plugin, but the “Fx” button doesn’t respond. I can’t click it. It doesn’t respond in any way when I hover over it with the mouse. And for some reason, my “Active Window Selection” menu under “View” is all greyed out and I can’t select anything.
    Is this a limitation of the Lite version?
    I’m sure it’s a simple thing, but several searches on here and the web at large have yielded no information.
    Mac OS X Mavericks
    DaVinci Resolve 10 Lite
    Trying to use FilmConvert
    Rohit Gupta replied 12 years, 3 months ago 4 Members · 4 Replies
  • Stefan José
    May 16, 2014 at 2:20 am
    I have the same problem. Have you found a solution?
  • Juan Salvo
    May 16, 2014 at 2:41 am
    Have you guys installed any OFX plugins?
    https://JuanSalvo.com
    https://theColourSpace.com
  • Stefan José
    May 16, 2014 at 2:43 am
    I have Film Convert Pro, Twixtor, Neat Video and so on installed. The round “fx” icopn displays button it is not a button. You cant click it
  • Rohit Gupta
    May 16, 2014 at 3:49 am
    You are using the button below the node graph correct? (right-most on the screen)
