Activity › Forums › DaVinci Resolve › Resolve dongle stops working
  • Resolve dongle stops working
    Posted by Timo Teravainen on January 21, 2014 at 10:02 pm
    Hi, I have a problem apparently with the Resolve dongle. Today the application suddenly froze when opening, and I had to reboot. After that, it always crashes when opening and “checking licences”. It says “resolve.exe stopped working”. I’m on Windows system. I have tried to uninstall and reinstall the software, but it doesn’t help.
    Margus Voll replied 12 years, 8 months ago 3 Members · 10 Replies
  • 10 Replies
  • Stuart Smith
    January 22, 2014 at 2:40 pm
    I have that problem when connected through a USB extender. Connecting directly to the computer fixes it for me
  • Timo Teravainen
    January 22, 2014 at 9:51 pm
    Hi, I’ve tried several ports directly to computer, doesn’t help. Tried the dongle with another computer and Resolve opened just fine.. but not on my main rig. Have installed and uninstalled several times but nothing seems to make a difference.
  • Margus Voll
    January 23, 2014 at 8:45 am
    your usb controller may have gone bad.
    most of the dongle problems are usb related and not the dongle.
    some machined will even burn their usb ports down if power draw exceeds manufacturers specs
    on pc machines i have seen.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 10, OSX 10.8.5
    MacPro 5.1 2×2,93 24GB
    GUI 4000 / GPU GTX 780
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Timo Teravainen
    January 24, 2014 at 9:53 pm
    Well, the usb controller seems to work perfectly with all other devices. Have tried both usb2 and usb 3 ports, as I suppose they have different controllers.
  • Margus Voll
    January 24, 2014 at 10:02 pm
    but if the dongle works on other machine then it leaves hardware or config.
    have you tried to re install resolve ?
    Margus
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Timo Teravainen
    January 25, 2014 at 9:10 pm
    Yes, installed and unistalled several times.. also the same thing with V 10.1. Don’t know if there’s some preferences file or similar that could be reset..
  • Margus Voll
    January 27, 2014 at 10:04 am
    Or maybe your os just gone bad.
    Maybe you could try clean install on separate disk ?
    In my experience it is simpler to clean install and not to try
    fix if there is no specific info what is broken. Usually it gives you more problems.
    Margus
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Timo Teravainen
    January 27, 2014 at 9:27 pm
    I agree, clean install may be the next step (sigh..) thanks for help!
  • Timo Teravainen
    February 2, 2014 at 8:05 am
    I did a clean intall of the OS and issue was solved, the dongle started working.
  • Margus Voll
    February 2, 2014 at 8:11 am
    Ok, then the os was broken so to say.
    Good to hear it solved the problem for you.
    Margus
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
