Activity Forums DaVinci Resolve Resolve crashQuits. Corrupted Project file…??
  • Resolve crashQuits. Corrupted Project file…??
    Posted by Francois Driessen on February 10, 2014 at 10:24 pm
    Help really appreciated here… Deadline is looming.
    After doing a day’s worth of grading on a TV episode, I’m now stuck with Resolve quitting without warning when I try to select between timelines. AND when I try to import new media.
    Started with FCP7 XML linking to a single flattened file. Duplicated the timeline. Then tried importing an updated version of the file as additional clip. Everything went south from there. Now, trying to import any media / selecting either one of the timelines causes Resolve to crashQuit so fast my head spins…
    I’ve exported the project and imported it on Resolve Lite on another machine. THE EXACT SAME THING HAPPENS…
    Other projects are fine. I can freely work with timelines and import media.
    How do I salvage this? Any advice?
    Francois
    FireTrigger Inc.
    https://firetrigger.com
    Francois Driessen replied 12 years, 6 months ago 5 Members · 15 Replies
  • 15 Replies
  • Margus Voll
    February 10, 2014 at 11:06 pm
    Check for corrupted stills.
    Try to export from projects list but without eels or stills and then re import.
    Some times it helps.
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 10, OSX 10.8.5
    MacPro 5.1 2×2,93 24GB
    GUI 4000 / GPU GTX 780
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Francois Driessen
    February 11, 2014 at 3:02 am
    Thanks. No luck.
    I was able to at least export an XML from the crippled project (since I applied some tweaks to the original XML). And generate stills for every shot. Created a new project and imported the XML. Then just applied the still’s grades to every shot in the new project’s timeline. Phew. Only lost about an hour trying to work around this.
    I think the thing that broke it was trying to import a ProRes file that had AAC audio on it by some fluke… But can’t say for sure.
    Anyone else had this happen?
    Francois
    FireTrigger Inc.
  • Laco Gaal
    February 11, 2014 at 8:17 am
    try what Margus has advised, export the whole project without stills (not the XML way).
  • Sascha Haber
    February 11, 2014 at 9:36 am
    You heard about Colortrace ?
    A slice of color…
    Resolve 10.1.0.021
    Colorist / VFX / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Margus Voll
    February 11, 2014 at 9:56 am
    Psst Sascha.
    Not giving out all the secrets 😉
    Margus
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Francois Driessen
    February 11, 2014 at 8:43 pm
    I did try it.
    Sadly, no joy… I’ll keep the method in my back pocket for next time if I have a project go wonky on me again to try.
    Francois
    FireTrigger Inc.
  • Francois Driessen
    February 11, 2014 at 8:53 pm
    My issue was that I could not touch any timeline. The moment I try to select either one of the two it crashQuits. Next time I’ll definitely try to copy in style like only Trace allows you to…
    But thanks anyhow, gents. Appreciate the help.
    PS: Your secret is safe with the me & the manual… 🙂
    Francois
    FireTrigger Inc.
  • Margus Voll
    February 11, 2014 at 9:05 pm
    Maybe you have some broken footage ?
    I would try to move some of it to the other directory part by part and see if it helps.
    Also do send in your crash report to BM.
    They are really clever figuring out which asset kills your project if it is assets fault.
    Margus
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Francois Driessen
    February 11, 2014 at 9:29 pm
    Thanks, M
    Resolve just quit without MacOs even brining up the Crash Log window. Where do I find the log to send to BMD? Is there a log somewhere in the system I can go look for?
    I have a sneaking suspicion trying to bring in ProRes footage that had AAC audio on it triggered the problem. But there was no way to bring it back after the trigger. Once I get these episodes out, I’ll try to replicate the problem.
    Francois
    FireTrigger Inc.
  • Margus Voll
    February 11, 2014 at 9:53 pm
    Mac: /Library/Application Support/Blackmagic Design/DaVinci Resolve/CaptureLogs.app
    that makes log file on your desktop if i recall correctly.
    Margus
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
