Resolve audio keyframes – mass delete / reset?
*** Post script — problem solved — see below ****
I realize it is not a full featured audio editor, but simple volume controls and fades are enough for most of my home videos. but…
If you use the audio mixer, and get it wrong — how can you fix it?
It creates potentially hundreds of keyframes marked on the audio track. You can grab them and move them around, but I can’t see how to actually remove them without deleting and re-inserting the audio clip (which may be part of a paired video you’ve already color corrected making it a bit more problematic).
Rerunning through it in real time with the audio mixer is an exercise in frustration, as the knobs move to match the original, not what you want now, it’s like a tug of war.
There must be a “reset to clip audio and start over” somewhere… am I just missing it?
Linwood
**** After posting this I found it, and didn’t see a way to delete the post. The inspector will let you both toggle through and change individual points, and also with the backwards circle reset them. I don’t see off hand a way to do multiple clips but this does redo a whole clip at once.
