Activity › Forums › DaVinci Resolve › Resolve and MAC OSX 10.7.4
Posted by Peter Chamberlain on May 11, 2012 at 8:44 amWith the recent MAC OSX 10.7.4 release there are a couple of GPU support issues we are looking into. Until we have a Resolve update for these we recommend using the configuration as specified in our Resolve for Mac config guide. https://www.blackmagic-design.com/support/detail/?os=mac&sid=3948&pid=4448&leg=false
PeterChad Terpstra replied 14 years, 3 months ago 5 Members · 6 Replies -
Yoram Tal
May 12, 2012 at 3:17 amThank you for the info.
The main problem is I couldn’t find an easy way to downgrade to 10.7.3I know you are working on a fix so Resolve will work on 10.7.4 Just keep us posted.
Thanks.
Tal -
Andreas Hylander
May 22, 2012 at 9:18 amI tried to reply earlier, but it seems it did not make it through…
Short recap:
1) I just upgraded. Resolve is dead.
2) It was a clients machine.
3) I will have problems explaning this to my client.Yoram Tal, can you share how you managed to downgrade?
And BMD, can we get an ETA please? This is not really a good spot.Thanks in advance,
Andreas
_________________________
Color
VFX -
Juan Salvo
May 22, 2012 at 1:53 pmResolve 8.2.1 beta 3 has been out since last week, and is meant to fix the 10.7.4 issue. I’d recommend installing it.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
Andreas Hylander
May 22, 2012 at 2:13 pmBrilliant, thanks a lot. Did not know that (either…) 🙂
/ A
Color
VFX -
Yoram Tal
May 22, 2012 at 2:50 pmI downloaded the latest beta.
Uninstalled the previous install with the supplied app.
Reboot.
Installed new version.
Worked.iMac 27 latest gen with ultra studio 3G.
I would also recommend sending an email to tech support.
Good luck and report back of how you fixed it. -
Chad Terpstra
June 10, 2012 at 12:52 amI’m using an Nvidia GTX470 and recently upgraded to 10.7.4. My performance with ProRes files has taken a hit. I did the uninstall & update to beta3 and still am having troubles. ProRes4444 files will play 24fps with no Nodes on but once I do any corrections (even just levels) it will jump down to 9 fps max. What else should I try?
