Activity Forums DaVinci Resolve Resolve 9, setting tape name for Avid
  • Resolve 9, setting tape name for Avid
    Posted by Ethan Holzman on December 14, 2013 at 7:06 am
    How does setting up the tape name work. I have messed around uint the conform panel, but the intricacies of how this work has eluded me.
    My problem is I am working on a feature film shot with the Canon C300, and we used Resolve to transcode to MXF and add a LUT. In some cases the LUT didnt work right and I need to re-transcode flat. In some other cases the Assistant overlooked that he was creating files with errors and I need to re-do those as well. But I don’t want to re-sync. I want to replace. And I am having a VERY hard time re-linking. Its been very spotty.
    I gave the specs to the assistant so I’m not clear on how I am getting a different result. He, the assistant has roll #s 6 characters long, shedding 2 superfluous digits from the roll #, but I am getting 8 places?
    There is something like this for output, but it only effects the name of the file created and not the meta data roll #.
    Michael Phillips replied 12 years, 9 months ago 2 Members · 1 Reply
  • Michael Phillips
    December 28, 2013 at 9:47 pm
    In the settings you want to go to “conform assist” and you have some choices that will be used in the REEL field of the file and output in the TAPE field when exporting MXF/DNxHD. I know v10 has it, but have shown up in v9 is the selection for “use filename” in the same settings area.
    Michael
