Activity Forums DaVinci Resolve Resolve 9: AVID Artist Color not working
  • Resolve 9: AVID Artist Color not working
    Posted by Florian Gintenreiter on November 12, 2012 at 9:21 pm
    HI!
    I have Resolve 9 running on a MacPro under 10.8.2 and an AVID Artist Color panel in my network. I used the panel on Resolve 8.x under 10.7.x with no problems, but since I upgraded OS and application Resolve does not “see” the panel and it’s little displays just have a box in them as opposed to values and menu items.
    The panel is connected correctly, because it works normal in AVID Mediacomposer, but that’s not what I need it for.
    I can’t quite remember, but I think I have added the Resolve App into the EUCON Preference Pane on my system before the upgrade to 10.8.2: Now I can’t get it in there. I move the App-icon in there, the panel asks me to restart the machine and when it’s restarted the preference pane is empty again.
    I have also checkedUSER/LIBRARY/PREFERENCES/EUPHONIX for file permissions, but I do have read/write there.
    Anyone know how to get my panel working with Resolve again?
    Thanks for your help!
    ________________________________________
    Director of Photography, Director, Editor
    Vienna, Austria
    Florian Gintenreiter replied 13 years, 9 months ago 2 Members · 2 Replies
  • Dwaine Maggart
    November 13, 2012 at 2:39 am
    You normally do NOT need to see Resolve in the Eucon Preferences window.
    You DO want to see your panel in the My Panels area of the Eucon Settings – Surfaces tab, and you want to see your Mac in the Eucon Settings – My Workstations tab.
    Assuming you have that, and assuming you are using Resolve 9.0.3, go into Resolve Preferences, Control Panels, and select None. Save the Preferences and restart Resolve. Login and go back into Preferences and select Avid Artist Color. Save the Preferences and restart Resolve. The panel should now be working.
    Dwaine Maggart
    Blackmagic Design DaVinci Support
  • Florian Gintenreiter
    November 13, 2012 at 9:01 am
    Thanks for the tip! It now works. For some crazy reason I thought I did exactly what you said before and it didn’t work. Very strange, but happy I can use Resolve with the panel again.
    Vienna, Austria
