Activity Forums DaVinci Resolve Resolve, 2x GPU’s Pro’s and Con’s
  • Resolve, 2x GPU’s Pro’s and Con’s
    Posted by Kieran Nicholas on January 23, 2019 at 1:19 pm
    Hey
    Ok so I am in the need of some advice. I am currently running one nVidia 1060GTX GPU, which is a 6gb card.. What I am wondering is, is it worth getting a second GPU (as above) to run in the machine. I’m rendering out EXR’s for Turnover at 4+k. The speed isn’t the issue, its more of running other things while this is working away. I also need to render ARRIMXF’s to EXR which I am using the Arri Converter to do, as well as create QT’s and run Avid to update cuts (yes sometimes all at the same time)
    The system is:-
    AMD Ryzen 7 3.6 16 core
    64gb Ram
    nVidia 1060GTX 6gb
    256SSD (Windows)
    4tb Media
    22tb Raid
    After some thoughts as to whether its worth doing or spend the bucks and get a bigger boat?
    Regards
    K
    Live Long and Prosper
    Kieran Nicholas replied 7 years, 8 months ago 2 Members · 2 Replies
  • Marc Wielage
    January 24, 2019 at 1:11 am
    Resolve is demanding enough that I think you’re better off using a second machine if you need to do background tasks while rendering. Use a network connection to copy files across when necessary.
  • Kieran Nicholas
    January 24, 2019 at 10:09 am
    Hey
    Not really an option as this is my own kit.. As I said speed isn’t really the issue, its more of the fact I have a lot of other background processes going on.
    K
