Activity › Forums › DaVinci Resolve › Resolve 11 Clone Tool
  • Resolve 11 Clone Tool
    Posted by Mark Baird on August 27, 2014 at 8:48 pm
    Okay, Davinci 11 is up and running and I am trying to clone a BMCC hard drive. I set it up as per the manual and hit ‘clone’. I see a 0% progress and it immediately changes to a red “error” message. No explanation, no hint… just “Error”. wow. makes it kinda hard to troubleshoot. any idea where I can find details on what the error is? the manual is pretty much assumes it works with out fail every time as it has no instructions for an ‘error’ message.
    I have tried cloning to one disk to several, to different ones, doesn’t work.
    Thoughts?
    Mark Baird replied 12 years, 1 month ago 2 Members · 2 Replies
  • Rohit Gupta
    August 28, 2014 at 9:04 am
    Are you on Mac or Windows or Linux? What is the filesystem on your source and target drive?
  • Mark Baird
    August 28, 2014 at 4:30 pm
    Windows 7 SP 1.
    I have tried several combinations of formats…
    1. coming from a disk directly out of a BMCC (exFat) attatched throu a SIIG USB 3 dock to a USB 3 attached exFat. Fails after a few minutes.
    2. BMCC(exfat) to combination of internal array NTFS and External USB 3 drives exFat. Fails immediately.
    3. Directory on the internal array (NTFS) to another directory on same drive (NTFS) failes after a few minutes.
    All files for #1 and #2 are generated by the BMCC in DNxHD 175.
    For #3 I tried BMCC DNxDH and also files from a sony nex-fs100 (avchd)
    The really anoying thing is that there is apparently no way to tell WHY the transfer failed which makes troubleshooting unnecessarily complicated.
    Also, realistically, when I get this computer into the field, it will need to do verified copies between exFat, NTFS, and LTFS (LTO 6 Drive) on a routine basis. When I have clients that use macs I will also need to transfer to their drives over thunderbolt. So it seems a far cry away from being able to do that at the moment.
    Also, when it was transfering it seemed REALLY slow. I know it’s varifying, but still…. even the internal disk array to itself should have been faster.
    MB
