Activity Forums DaVinci Resolve Resolve 10 and Avid Artist Color Suggestions
  • Resolve 10 and Avid Artist Color Suggestions
    Posted by Evan Kultangwatana on November 5, 2013 at 4:00 pm
    Very pleased with Resolve 10 beta! Thanks to the team for all their hard work.
    Was working last night, and noticed a couple things when using the Artist Color: contrast knob barely responds to input, and the square window position controls didn’t seem to work
    And a feature request: mapping the RGB mixer control to the six knobs. I have become increasingly reliant on this tool for a wide range of functions. Would also be great to be able to toggle the preserve luminance function.
    On the subject of toggling, would appreciate a quick way of toggling the gang functions for the curves, ysfx, soft clip, etc. I end up having to dig through the UI which slows me down.
    Also, is there a published guide for the panel mapping?
    Looking forward to the final release.
    Tang Qiang replied 12 years, 5 months ago 6 Members · 8 Replies
  • 8 Replies
  • Guillem Ventura
    November 5, 2013 at 10:55 pm
    Basically you are complaining about the same behaviours of R9…
    Has there been any change?
    Is the response faster, with less lag?
    What version of EuControl are you using? I tried 3 and it was so bad I downgraded to 2.7
    http://www.malgeniofilms.com
  • Evan Kultangwatana
    November 6, 2013 at 12:02 am
    Using Eucon 3.0.1 and it feels responsive enough. No connection issues.
    Mapping has been reworked and is mostly the same, save for a few things. Bank 1 and Bank 2 behave differently.
  • Luca De grandis
    November 8, 2013 at 5:03 pm
    Are you using Maverick ? Because with maverik I’ve an issue with NAV and PAGE button. Previously, with OS X 10.8, everything was fine.
  • Richard Starkey
    February 8, 2014 at 4:27 am
    I’m having exactly the same problem.
    Wheels are fine but the Nav and Page buttons have a lag of about 4 sec, making them impossible to use.
    Did you find a solution?
    Mavericks
    Artist Control 3.1
    Resolve 10.1.0lite.021
  • Luca De grandis
    February 8, 2014 at 4:32 pm
    Yes, you have to turn off the nap option from eucontrol app.
    I’m not in front of my Mac, but you have to right click on the eucontrol icon and disable nap option ( I don’t remember exactly the name)
  • Richard Starkey
    February 8, 2014 at 6:04 pm
    Ciao Luca!
    Gracias, I shall try that when I switch it on again.
    Richard
  • Genta Tamaki
    March 5, 2014 at 4:19 am
    Hi
    I solved this plobrem!
    ,I am a Japanese,so i can’t use English so much.sorry
    On my MacPro(Early 2009), I use Resolve 10 with Marvericks and Artist Color.
    NAV button ‘s Probrem was solved.
    First Check Your Mac’s NIC’s Subnetmask!
    on My Mac ,
    Ehternet 1(for LAN&Eucon) IP:192.168.1.11 Subnet:255.255.255.0
    Ethernet 2(for NAS) IP:192.168.10.111 Subnet:255.255.255.0
    This settings, NAV Button response is tooooooo slow
    but after Change setting
    Ethernet 2(for NAS) IP:192.168.10.111 Subnet:255.255.0.0
    NAV Button’s response is Fine!
    Try it!
  • Tang Qiang
    April 5, 2014 at 3:45 pm
    I have encountered the same issue and finally got it solved. I’m running Mavericks 10.9.2, Eucontrol 3.1.2 and Resolve 10.1.2.
    As Luca De Grandis suggests, it is the App Nap that is causing the problem.
    And for those who run into this thread looking for a solution:
    Normally, you can use Finder, navigate to EuControl and MC_Client, right click, click on “Get Info”, then check on the “Prevent App Nap” checkbox. This should solve the problem.
    Strange thing is, I don’t have such a checkbox there. I do have them for other apps like Davinci Resolve. I had to open Terminal and run the command as below:
    defaults write com.avid.eucontrol NSAppSleepDisabled -bool YES
    Now everything seems to be ok.
