Activity Forums Adobe After Effects Resolution Question
  • Resolution Question
    Posted by Stephen Hockman on July 22, 2005 at 1:26 am
    I was wondering…When I create a PSD file to use in my after effects or final cut pro project, does it matter what dpi i use? I have been using a 72 dpi, but should I be using something higher? Or does it not matter?
    Andrew Yoole replied 21 years, 2 months ago 3 Members · 2 Replies
  • Jeff Cochran
    July 22, 2005 at 1:51 am
    72 dpi is what you want. If your going to enlarge the image in AE or FCP, just make it larger.
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
  • Andrew Yoole
    July 22, 2005 at 5:09 am
    The only time DPI is relevant between PS and AE is if you are cutting and pasting mask shapes between the two, in which case 72dpi is the one to use. Otherwise, DPI is completely irrelevant to video. There are no inches in the video world.
