Activity › Forums › Adobe After Effects › resolution question
  • resolution question
    Posted by Pierre5454 on September 14, 2007 at 10:49 pm
    hello all
    I am working on an after effects video that will be displayed on a samsung TFT-LCD screen. It is a 32 inch wide screen with 4,000:1 dynamic contrast ratio (whatever that means). when the file is burned to a dvd, and played on the monitor, the resolution seems really bad. Is it a matter of changing the composition settings or is it something when I am rendering it?please help me, thanks.
    Darby Edelen replied 19 years ago 3 Members · 2 Replies
  • Steve Roberts
    September 15, 2007 at 1:40 pm
    Regarding composition settings, you’re stuck with 720×480 (in North America, at least) for DVD. If you don’t use that pixel resolution, it won’t play at all, or it won’t compress to the necessary codec. You have no choice in the matter.
    DVDs must be encoded with the MPEG-2 codec, which is a compromise between image quality and data rate, allowing us to play videos on a removable disc on all DVD players.
    That said, it’s not the best quality. You can try to squeeze the most out of it by having the highest-quality source possible before compressing to MPEG-2. If you’ve generated the images in AE, you can render your movie to the Animation (lossless) codec or a 10-bit codec before compressing to MPEG-2. However, if your source is, say, DV, then you’re stuck with the low quality of DV, which is further compressed when you compress to the necessary MPEG-2 codec.
    Also, when you compress to MPEG-2, you can use a setting which is VBR (variable bitrate) with the highest data rate offered by the compressor. Check your compressor app’s settings. I recommend a specialized compression app such as Apple’s Compressor, or maybe Squeeze.
    Does that make sense?
  • Darby Edelen
    September 15, 2007 at 4:21 pm
    Standard Definition DVDs are stuck at standard TV resolution: 720×480 for NTSC or 720×520 for PAL. When you view them on a computer that is not set to a 720×480 resolution (actually 640×480 after PAR correction) then they must be res’d up to be viewed at full screen. If you view them on a computer at “100%” or “Original” size, that’s the resolution that the footage actually is.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
