Activity › Forums › Apple Final Cut Pro Legacy › resolution / quality
  • resolution / quality
    Posted by Leon Klein on May 4, 2007 at 4:18 am
    i exported an animation from combustion as a quicktime (when i play it in quicktime it looks perfect..) and imported it into FCP..
    then i added the music on FCP and i exported it again but it never looks as good as the file i exported from combustion… even if i use uncompressed or DV.. what am i doing wrong?
    what resolution show i use for keep using it in a DV project
    should i use export->using quicktime conversion ?
    thank you!
    leon.
    David Roth weiss replied 19 years, 5 months ago 2 Members · 1 Reply
  • David Roth weiss
    May 4, 2007 at 6:11 am
    Leon,
    1. There are a zillion flavors of QT and Combustion can render out to just about any of them. Exactly what type of QT did you render to in Combustion?
    2. And, there are a zillion Easy Setups in FCP. What is your Easy Setup for the FCP project you imported the QT file into?
    Without being very precise about these things there is no way anyone here can possibly give you an accurate answer to your question.
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
