Activity › Forums › Adobe After Effects › Resolution
Resolution
Posted by Cyprusx on June 28, 2007 at 7:41 amHi,
Is there any way to make a bad quality video get better quality. Its a .mov file.Frank Hardie replied 19 years, 3 months ago 4 Members · 7 Replies -
Mark
June 28, 2007 at 10:07 amThats a pretty vague question…it is a little like asking if you can get a car to run better……
That said 🙂 There are a number of things you can do, but if the video is really bad, I like to embrace the “badness” of the video and build something that is grungy…make it look like you meant it to look that way.
Be a little more specific and maybe we can give a solution.
Regards
Mark
Steve Roberts
June 28, 2007 at 12:49 pmIf it’s really bad, pixellated with compression artifacts, the answer is no.
You can try to remove some noise with the “remove grain” effect, but if you go too far, the picture gets blurry.
Cyprusx
June 28, 2007 at 7:49 pmwell i shot a video, and the resolution is really bad, and blocky and i was wondering if there is any way i could get it to look better,smother clearer, anything, im open to any suggestions.
Steve Roberts
June 28, 2007 at 8:26 pmEffect>noise&grain>remove grain.
The filter samples noise from a frame of your chocie, then calculates a method of removing that specific noise from the shot.
For more info, try searching the COW for “remove grain”.
Cyprusx
June 28, 2007 at 8:43 pmI haven’t got that option,
P.S do you no any site were you can get free black drop videos. like detonationfilms.com
Frank Hardie
June 28, 2007 at 9:59 pmDo a google search for the “NeatVideo” plugin (from the makers of the NeatImage plugin for PS). It does an amazing job of cleaning up grainy video. They have a free trial version available.
