Activity › Forums › Maxon Cinema 4D › Resizing objects from different points
  • Resizing objects from different points
    Posted by John Smith on March 18, 2011 at 4:58 am
    Hello, I am trying to resize a tall cylinder from one end of the cylinder so it looks like its growing. How do I make it so that it doesn’t grow from the center outward? Thanks.
    Randy Johnson replied 15 years, 6 months ago 2 Members · 1 Reply
  • Randy Johnson
    March 18, 2011 at 7:41 am
    Since you are using a primitive you cannot change the axis.
    You could however put it in a null object and then Scale the null. It will then scale from the nulls location.
    /Randy
