Activity Forums Adobe After Effects Resizing compositions from SD to HD
  • Resizing compositions from SD to HD
    Posted by Steven Jones on April 29, 2008 at 6:03 pm
    I am working on a project that has some animations that were previously created in a Standard Def format. We will be re-using these animations but will now be using a 1920 x 1080 HD format. The animations I am trying to use are vector animations. What is the best way to upconvert these compositions without losing the complex animations (null effects, scale and position transformations, etc.) Is there a simple way to do this?
    Darby Edelen replied 18 years, 5 months ago 2 Members · 1 Reply
  • Darby Edelen
    April 29, 2008 at 8:14 pm
    The alternative would be to drop the SD comp into an HD comp, use Fit To Comp Height (or Width if you want a full 16:9 frame but this will cut the top and bottom of the 4:3 frame), and enable continuously rasterize/collapse transformations on the SD comp.
    Unfortunately this doesn’t quite work if there was a 3D camera in the SD comp, translating the coordinates of the camera from SD to HD can be a major pain.
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
