Activity › Forums › Apple Final Cut Pro Legacy › resizing an image sequence
  • resizing an image sequence
    Posted by Tad Newberry on February 1, 2006 at 4:01 am
    i’ve got a short animation from Lightwave that i’ve imported but want to shrink the whole thing a bit and move it to a corner of the frame. i select all the frames in the timeline and try scooting them in the canvas, but only that single frame gets moved. is there a way to effect all on a move like that?
    thanks for helping out a bonehead,
    jtn
    Tad Newberry replied 20 years, 7 months ago 2 Members · 2 Replies
  • Jeremy Garchow
    February 1, 2006 at 5:48 am
    Bonehead:
    I don’t know anything about Lightwave, but it sounds like you have an image sequence?
    You can either open the image sequence in QT Pro and export a qt movie, or, you can put your image sequence in a timeline in FCP, and then drag that timeline into another timeline (called nesting) and then the image sequence will appear as one clip with which you can apply global actions/effects.
    Jeremy
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
    ATTO 42XS <> Huge Systems 4105 Fibre
    OS 10.4.2 <> QT 7.0.3
  • Tad Newberry
    February 2, 2006 at 6:00 am
    Thanks Jeremy!
    THAT is a very cool feature! I did the nesting thing. On a related idea, I also found out that when you change the default single frame import size, you have to reimport your still so it will have the new length when put into the timeline. Most people probably knew this, but i just “discovered” it today. Maybe it will help someone else, too.
    jtn
