Activity › Forums › Adobe After Effects Expressions › Resize one side of a box (lower third) to text
  • Resize one side of a box (lower third) to text
    Posted by Ella Turner on September 27, 2018 at 4:58 pm
    I’m trying to get a lower third to re-scale according to the text I’m typing in – but I only want the right side of the box to re-size.
    I’m using code on the ‘size’ of the rectangle path of my shape layer at the moment – do I need to play around with the position too?
    The code below is the one I’ve been using when I need both sides to adapt.
    margin = 23;
    text_width = thisComp.layer("Text 2").sourceRectAtTime().width;
    text_height = thisComp.layer("Text 2").sourceRectAtTime().height;
    box_width = text_width + margin*14;
    box_height = text_height + margin*2;
    [box_width, box_height]
    Kalleheikki Kannisto replied 8 years ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    September 27, 2018 at 7:18 pm
    Moving the anchor point to the left edge should do it.
    Senior Graphic Designer
