Activity › Forums › Adobe After Effects › Resize object from another point?
Posted by Olly Lawer on August 26, 2012 at 7:24 pmHi,
Another mental block. How to I resize an object from the top, without it affecting the bottom?
i.e. I have a rectangle shape layer. It sits on an axis of a graph. I want to pull down the top and keep the bottom sitting on the x axis. However, when I pull the handles down on the top, it affects the bottom too, lifting it from the axis.
Olly Lawer
John Cuevas replied 14 years, 1 month ago 6 Members · 6 Replies -
Vishesh Arora
August 26, 2012 at 7:42 pmMR. Lower
Whenever we scale any object, it will affect both the direction along X and Y axis i.e. top and bottom or right and left respectively.
You have to adjust the position of the Rectangle Shape Layer after resizing.
If you want to have this feature then you can go for another way to create rectangle shape.
1. Make a solid layer.
2. Apply Rectangular Mask.Now this will work as a rectangle shape layer and you can change the shape in any direction you want just by manipulating the mask shape.
Vishesh Arora
VFX and Motion Graphics Artisthttps://digieffects.wordpress.com
Tudor “ted” jelescu
August 26, 2012 at 8:56 pmChange Anchor Point location to the bottom using the Pan Behind tool.
Tudor “Ted” Jelescu
Senior VFX Artist -
Tom Daigon
August 26, 2012 at 10:16 pmTutor nailed it.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
John Cuevas
August 26, 2012 at 10:38 pmHere’s a ‘name your own price’ script, repositionAnchorPoint that you might find handy for quickly adjusting the anchor point for scaling purposes.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Kevin Reiner
August 27, 2012 at 6:56 pmJust curious John – how is that script different from the pan behind tool?
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23″ flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig -
John Cuevas
August 27, 2012 at 8:40 pmIt’s not really. In prior versions before anchor point snapping, it was a lot quicker to use the script and snap the anchor point to the top of a layer, a corner or center. I still use it and for me, find it a bit quicker to use the script to snap my anchor point to a position rather than try and drag it to where I want it to go.
