Activity › Forums › Adobe After Effects › Residual frames in After Effects composition won’t go away
Posted by Matteo Vegetti on June 6, 2014 at 3:55 pmHello there,
first time poster, long time reader though.
I’m having a serious yet weird issue with AE and I am unable to find a solution either here or on the internet.
To the point: I have instances where text or images are still visible one frame later after they’re no longer on the timeline, like this exampleWhat’s weirdest is that even if I toggle the visibility of ALL layers or erase them all… I still see that spurious image (throughout the composition though, not only on that frame)
I’ve tried emptying the cache, changing layer order… even reinstalling AE doesn’t work.
Any idea?
I’m lost
Matteo
Daniel Sorensen replied 8 years, 7 months ago 10 Members · 24 Replies -
Joseph W. bourke
June 6, 2014 at 4:55 pmThe only other thing I can think of is updating the driver for your video card. That’s about the only other place where an image could sit in a buffer and maybe not get erased.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Matt Davis
June 6, 2014 at 5:28 pmShot in the dark here…since you’ve tried the obvious things…could you try copying all of the layers into a new comp? Don’t pre-compose them. Straight up copy and paste into a brand new comp.
Shouldn’t make a difference, the After Effects equivalent of unplugging and then plugging it back in, but who knows?
That’s all I have to add, sorry. Maybe dance counter-clockwise around the computer and sprinkle salt on the case… lol
Good luck.
Chris Brett
June 6, 2014 at 5:34 pmHi – had the same once …..
– seem to remember I copied every layer I needed into a new composition …
… cant quite remember all the details — basically I built another project file and it went away…..
—- sorry this is a bit vague but am pretty sure thats how I solved it …
———————————— chris —
Michael Szalapski
June 6, 2014 at 5:47 pmAnother shot in the dark: Any chance you have another copy of the letters layer that you don’t see because they have the “shy” switch turned on?
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Matteo Vegetti
June 6, 2014 at 8:25 pmThanks for all the advice but none of this really worked (haven’t tried the counterclockwise dance yet though!).
Updating driver, changing to new comp, turning off shy flag didn’t help…I somewhat think the issue is related to dynamic linking but I cannot figure out how.
Matteo
Michael Szalapski
June 6, 2014 at 8:42 pmRevealing all the shy layers didn’t make any text layers appear in the timeline? Darn, I was hoping that was it!
Try importing that project into a new project.
If that still doesn’t work, do you have another computer with AE that you could open that project on? Alternatively, could you pass your project file onto one of us to look at?
– The Great Szalam
Chris Brett
June 6, 2014 at 9:48 pm– hi again ….
– probably you tried this anyway – but if I remember correctly I actually copied only the layers needed and pasted them into a new comp ——
————– I say this because if you open the project in a new comp I assume it will also open the problem as which is presumably cunningly tucked away somewhere……..
—————— chris —-
Matteo Vegetti
June 7, 2014 at 7:16 amSo, copying just the layers in a new comp didn’t work, as well as importing the comp into a new project.
Even if I try to open a completely new project this is what I get: aargh
Can you see the little $%&”!! rosengarten image in the top left comp thumbnail?BUT opening the project on another computer won’t show this problem… (or the text going one frame further after its end)
Michael Szalapski
June 7, 2014 at 3:34 pmThat’s…that’s weird.
If you uninstall, run the CC Cleaner, then reinstall and it’s still there, I’m saying your machine is haunted.
– The Great Szalam
Walter Soyka
June 9, 2014 at 3:05 pmI have found that sometimes a stubborn frame like this can persist if its both in the RAM cache and the disk cache. Emptying the disk cache isn’t enough, because if it’s still in RAM, the bad frame can get written back to disk right after you clear it.
Are you on Ae CC? If so, try Edit > Purge > All memory and disk cache.
If you’re on CS6, or if you tried the above and didnt’ work, try this:
In Preferences > Media & Disk Cache, first disable the disk cache (which prevents new frames from being written to it), then empty the disk cache.
Preferences > Media & Disk Cache > re-enable disk cache.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn]
