Activity › Forums › Adobe After Effects › Residual frames in After Effects composition won’t go away
Daniel Sorensen replied 8 years, 7 months ago 10 Members · 24 Replies
Michael Szalapski
June 9, 2014 at 3:57 pmAlso, what exact version number of AE are you using (down to the last decimal point)?
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Matteo Vegetti
June 10, 2014 at 1:24 pmI haven’t tried running CC cleaner after uninstall… I’ll try that as a last resort as soon as I’ll have a spare half an hour and keep you posted.
Matteo Vegetti
June 10, 2014 at 1:29 pmI’m on CC 12.2.1.5 but I had the same problem before this update.
Walter Soyka
June 10, 2014 at 1:30 pm[Matteo Vegetti] “I’m on AE CC and no, purging the cache didn’t work!”
Understood, but did you also try disabling the cache and then purging both the disk cache and RAM before re-enabling it as I suggested?
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Walter Soyka
June 10, 2014 at 1:49 pmSorry I was unclear.
This is not a solution, but a troubleshooting step. If you change the resolution or framerate of the comp with the ghost thumbnail, does it persist?
Walter Soyka
Matteo Vegetti
June 10, 2014 at 2:02 pmNo worries and thanks again for helping!
Well, if I change the frame rate nothing happens BUT changing the resolution gets rid of the ghost image. Returning to the original size though brings back the spurious frame. -
Walter Soyka
June 10, 2014 at 2:04 pm[Matteo Vegetti] “Well, if I change the frame rate nothing happens BUT changing the resolution gets rid of the ghost image. Returning to the original size though brings back the spurious frame.”
This still sounds very much like a cache issue to me.
What if you close Ae and manually delete the entire Ae cache folder?
Walter Soyka
Matteo Vegetti
June 10, 2014 at 2:22 pmNo chance… didn’t work.
Cache had been my first thought as well but whatever I tried it didn’t work.
I’ll try to uninstall and run CC cleaner and keep you posted.
