Activity Forums Adobe After Effects resetting selected bits and bobs
  • resetting selected bits and bobs
    Posted by Al on December 6, 2005 at 9:29 am
    is it possible to do selective resets within plug ins like 3D stroke? I don’t want to reset all of my parameters, only, for example, the repeater. looking for a shortcut to doing it manually… anyone?
    Andrew Kramer replied 20 years, 9 months ago 2 Members · 1 Reply
  • Andrew Kramer
    December 6, 2005 at 8:08 pm
    Yeah, I don’t think you can do this but you can always add an instance of the effect at it’s default state and select the parameter you want to revert (the name that is) then copy and paste to the working version of your plugin. Some plugin have parameters all controlled by one keyframe stopwatch which can be trouble but this sould work for particular since all the parameters are pretty much keyframable.
    however the state of your working parameter must not be keyframed or it will only paste the default state to that keyframe.
    Good Luck,
    Andrew
