Activity Forums Maxon Cinema 4D Resetting Scale
  • Resetting Scale
    Posted by Sean Lourez on October 9, 2013 at 4:49 pm
    Hey Everyone.
    Ive been looking for an answer to this for a while, but cant seem to find the right one.
    I have an object that when i made it, it was 200ft long, Ive since scales it down to 18ft, which is fine. I now want to reset the scale of the object but keep its size at 18ft, I know i can freeze transformation, but the objects size is still the original 200ft, Can i reset the scale to 1 and the object size to 18ft without having to re-size again?
    Any Help would be awesome.
    Adam Trachtenberg replied 9 years, 11 months ago 3 Members · 2 Replies
  • Andrew Orlow
    October 7, 2016 at 4:48 pm
    The same problem
  • Adam Trachtenberg
    October 7, 2016 at 10:36 pm
    I’m not sure I understand the problem. If you want to resize the object use the scale tool in Model Mode. Or if you want to do it precisely for a whole scene, use the Edit>Scale Project function.
