Activity › Forums › Apple Final Cut Pro › Reset start timecode of clip in Library?
  • Reset start timecode of clip in Library?
    Posted by Anatoly Ivanov on March 21, 2015 at 8:51 pm
    Is there any way to reset the start (and hence, the end) timecode of a clip (video or audio) inside the Library?
    For example (as in the image), set 02:10:08:12 to 00:00:00:00?
    Haven’t found an interface for that (the field is not editable). Maybe a SQLite edit?
    ANATOLY IVANOV / FILM / PHOTOGRAPHY / DESIGN / PROSE
    https://www.anatolyivanov.com/
    Anatoly Ivanov replied 11 years, 6 months ago 4 Members · 4 Replies
  • Bret Williams
    March 21, 2015 at 10:53 pm
    FCP legacy had this option. Why would you want to set it to zero? If you’re looking to just see a counter you can just drag out a range and it will show a duration, which is almost as good as a counter.
  • Noah Kadner
    March 22, 2015 at 12:35 am
    Definitely don’t go mucking with the database in the finder- could have nasty unintended consequences. I believe what you want to do is set AUX timecode- that’s not something FCPX does. The timecode embedded in the QT is what it shows. Of course you can always add a generator on a timeline and make it whatever TC you want.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Doug Metz
    March 26, 2015 at 7:19 pm
    You could, alternatively, remove the clip from your library and ‘brute force’ your way to 00:00:00 by deleting the timecode track from the file directly in QT Pro… not that you should, necessarily, but it would get you there.
    2¢
    Doug Metz
    Anode
  • Anatoly Ivanov
    March 30, 2015 at 2:23 pm
    Oh wow! Bret, Noah and Doug, my apologies, haven’t noticed your replies.
    All Creative Cow notifications went into Spam. I’ve since added a new Sieve rule.
    So, the problem I have is I got handed an FCP X project, semi pre-cut (just the selects with sound synced in), but, someone must have had a problem with timecode settings (maybe in-camera) during the shoot — the Canon C300 files have nothing to do with reality. Or, it might have happened during the MXF ingest.
    I also recall having seen similar issues with super-simple .wav files from Zoom recorders (arbitrary timecode shift when ingested by FCP X).
    Hence my question.
    Nothing fatal. It just gets on my nerves when I Shift+F to the library and see the values. Or when I need to reference a precise range (make notes).
    I’ll maybe try resetting elsewhere as Doug suggests. Maybe in After Effects or Resolve, when we get there.
    I fear FCP X keeps the meta-data separate, though. So when I replace the file, the timecode won’t be fed from the .mov but from the SQLite.
    Thanks guys!
    (yeah, it was easier in pre-X!! argh!)
