Activity › Forums › DaVinci Resolve › Reset Scopes?
  • Reset Scopes?
    Posted by Andrew Smith on August 30, 2011 at 2:56 am
    Hello
    I remember there used to be some adjustment options or dials on the scopes – I moved the scopes to my other screen and set them up to my liking and saved settings (as shown below) – i realize I no longer see those parameters available in each window. I tried resetting and moving/resizing but no luck.
    Am i just sleep deprived? I just tried searching through the manual but cant seem to fins the reset option to get it back. Also curious how you guys suggest setting them for HD & Film – like in Color it was best to set to 75% i believe – is there anything like that with Davinci or is it fine the way it defaults?
    You can see below how they appear in the manual with those dials and adjustment parameter options…
    thanks you in advance for a probably really silly question.
    Andrew Smith replied 15 years, 1 month ago 1 Member · 1 Reply
  • Andrew Smith
    August 30, 2011 at 3:01 am
    Ha! sorry gang, just tried double clocking on the actual scope and like magic those parameters return!
    I guess I am still curious about the 75% question and what if anything else I should be aware of with these sliders??
    cheers
    MacPro 4,1 OSX 10.6.8 / FCS3 / CS5
    2.26 ghz 8-core / 24GB RAM
    Nvidia GT 120/285 combo
