Activity Forums Adobe After Effects Expressions Reset rotation each revolution
  • Reset rotation each revolution
    Posted by Mikko Miettinen on September 15, 2017 at 12:43 pm
    Hi
    I´m trying to rotate a shape through expression so that on each revolution rotation value resets to 0. So basically I want a shape rotate only through 0-360 degrees and then reset to 0 degrees again and continue rotating. I don´t want to use keyframes and loop expression.
    Nithish Kumar replied 6 years, 4 months ago 3 Members · 3 Replies
  • Dan Ebberts
    September 15, 2017 at 6:00 pm
    Something like this maybe:
    dur = 2; // rotate 360 degrees every 2 seconds
    ((time-inPoint)*360/dur)%360
    Dan
  • Mikko Miettinen
    September 15, 2017 at 6:28 pm
    Hi Dan,
    Thank you! You´re the boss! ☺ Could not get my head around this.
    Mikko
  • Nithish Kumar
    May 3, 2020 at 12:45 pm
    Could you break this down in words plz ?
