Activity Forums Adobe Premiere Pro Reset Premiere to defaults Control Z ?
  • Reset Premiere to defaults Control Z ?
    Posted by Mark Perez on August 10, 2005 at 3:16 am
    How do I reset Premiere to the default ? I know it is in the posts, but can not find it. shift z ? control z ???
    thanks
    mark
    Mike Velte replied 21 years, 1 month ago 4 Members · 5 Replies
  • Craig Howard
    August 10, 2005 at 5:27 am
    I do not think there is any default. What do you want to achieve ?
    Using a preset to set up a project may be what you are looking for.
    Ctl Z is “Undo”
  • Mark Perez
    August 10, 2005 at 5:58 am
    Thank you for the reply, When you start premiere (launch the app) there is a way to reset, the preferences ? or what is the file to delete. Sorry not much help with the verbage, but maybe this is a bit better explaination
    thanks again
    mark
  • Mike Velte
    August 10, 2005 at 11:48 am
    Hold the Shift and CTRL keys down while launching Pro, then reset your Preferences.
  • Steven L. gotz
    August 10, 2005 at 4:49 pm
    Hmmm. I could be wrong on this, but I thought Ctrl-Shift was for Premiere 6.x and just Shift for Premiere Pro.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Mike Velte
    August 11, 2005 at 11:43 am
    Thanks Steve, I stand corrected.
