Activity › Forums › Apple Final Cut Pro Legacy › Reset Audio/Video Division on the Timeline
  • Reset Audio/Video Division on the Timeline
    Posted by Chris Walsh on July 1, 2011 at 12:53 pm
    The grey “divider” slider on the right hand of the timeline/sequence window is the bane of my existence.
    Inevitably, as I do audio work on a project, the audio/video track ratios get shifted, until I can only see one video track. and the then I can’t change back. The scroll arrows don’t function. Neither does the grey divider. I can make my audio track area larger, but not the video.
    Is there anyway to reset the track layout? I tried trashing my preferences with no luck. Next step will be to copy the entire sequence to a new empty sequence.
    Hopefully there is a basic command I don’t know about.
    Chris Walsh
    http://www.musicfog.com
    Silver Spring, MD
    Final Cut & AVID MC5
    Former Windows User and edit* lover
    Chris Walsh replied 15 years, 3 months ago 1 Member · 1 Reply
  • Chris Walsh
    July 1, 2011 at 1:00 pm
    I figured it out. Grab and hold the center slider in the divider to pull the whole divider down. Very intuitive. God forbid I should use the edge the windows, or any part of UI that changes when I hover.
    Chris Walsh
    Silver Spring, MD
